Should i get an Apple TV?
Babyt
May 24, 2010
1,013
64
I recently inherited an extremely large (400+) DVD collection. I was thinking if burning these to my external harddrive . What I want to know is should I get an Apple tv to play these on? Im not really sure what the Apple tv does honestly.... If I got one, would I store onto the Apple tv? Or use "AirPlay" (which I have NEVER used and rather confused about) thanks.
Also I have Netflix too so I could stream with that.
Smarty2600
Apr 23, 2011
344
11
Well I don't think the Apple tv could directly take your burned DVDs but if you burn them and use the air video app you could stream the burned movies to your iDevice and then AirPlay that app to the Apple tv. The air video app has a server that runs on your computer, I'm pretty sure it could find your external hard drive. Then open the app and then AirPlay the app. Also I'm reasonably sure that while using AirPlay you can actually continue to airplay in the background and use the iDevice as normal. And the Apple tv has Netflix streaming built in. The Apple tv comes with a remote but it also has an app with a full keyboard you can use on your iDevice. It sounds like the Apple might be a good fit for you depending on if air video works well for your needs, I would check out the developers site for more info.
Also I don't think the Apple could be hooked up to a monitor but maybe, the way to hook up an Apple tv is hdmi.
Hondamaker
May 14, 2007
9,946
655
58
Fairborn, Ohio
You can burn and convert your movies and import them into iTunes so you could play them on your Apple tv, or you could copy them to an external hard drive like I did and then use air video to stream through your iDevice to your Apple tv. It's really very easy!
FriarNurgle
Sep 29, 2010
You would need a lot of storage for 400 movies.
I love the idea of a home media server but never did it. It would take way too long to rip all the DVDs and most of them are available streaming on Netflix anyway. Granted Netflix still doesn't have subtitles on the ATV yet.
The kids and I use the ATV mainly for Netflix anyway. I wouldn't mind swapping out the ATV for a MacMini one of the days.
chris
Administrator
Administrator
Jun 10, 2006
11,817
1,707
Long Island, NY
If your plan is to watch these movies on a monitor, that would be hooked up to your Mac, then I would strongly urge you to consider using Plex. It's free and incredibly awesome. You create a folder that you designate for 'Movies' on your hard drive. Rip your movies to that folder. Title them in the format, Title (YEAR).m4v. For example, The Social Network (2010).m4v. Plex will go out to IMDB and grab all the meta data. Within the front end of Plex, you can browse movies with cover art, background art and information about the movie. It's really incredible.
Down the road, you could easily move this setup to an HDTV, with a Mac of some sort being the go-between.
Michael Baturin
Jul 11, 2007
1,751
244
33
South Jersey
So you have 400+ DVDs, an external Hard-Drive (hopefully large), and MacBook Pro - and you are considering a monitor for the MacBook Pro. Your question is how can you use an Apple TV 2 to stream those movies to your TV?
My Answer: You would need to spend a lot of time ripping and converting the movies to be added to your iTunes Library They can be added to iTunes even if stored on the external HD, but will only be accessible when the external HD is plugged into the MacBook Pro. Once there, the Apple TV will stream them from your MacBook Pro with HD attached to the TV. You will need to rip the DVDs no matter what you do if you want them to be part of a digital library. Therefore - having a monitor to hookup to the MacBook Pro would do little more than adding a larger screen to watch movies (definitely nice though).
As Chris said, Plex would be a good way to organize the content in this fashion as it creates an awesome User Interface automatically finds content related art/metadeta to your movies. I believe Plex can be run on some Blu-Ray players and maybe PS3 that hookup to your TV as a media server (like AirPlay but just through this software installed). This may be an option to consider.
To clear up your confustion on Apple TVs
Apple TV 1 had internal storage and was able to store I believe up to 320GB modified - or so I've heard. Don't go this route for that many movies.
Apple TV 2 has no internal storage and is meant to be used purely as a streaming content device from Youtube, Netflix, Your Home Computer(s), Apple Movies/TV Shows, and some others.
Phil DeLong
Jan 16, 2011
68
IN
That sounds absolutely amazing, I'm checking it out right now.
Babyt
May 24, 2010
1,013
64
Lol I'm not gonna burn All the movies. Just the ones I haven't seen and I'm interested in.
Babyt
May 24, 2010
1,013
64
I will definitely get plex. Thank you :)
Babyt
May 24, 2010
1,013
64
the reason I want an Apple tv is that ALOT of times I can't use my Mac to watch videos (my family's on it or I'm doing something else on it)
That's why I'm debating getting the Apple tv
Also I'm getting the monitor for purely other reasons. I was just asking if I could hook up the Apple tv to it cause I know nothing of monitors and cables.
Thanks for the info on the Apple tv versions
And I have a 2 tb external harddrive my parents bought and don't use that I plan on commandeering for some movies.
Michael Baturin
Jul 11, 2007
1,751
244
33
South Jersey
2TB is definitely more than enough. Is the Macbook Pro somewhere when your family uses it that it can have the HD always attached? If so, this would solve your problem as you could stream from it while they use it. However if they use it around the house in a more labtop type way, you would have to make sure the HD was attached before you could watch your movie.
The Apple TV hooks up via HDMI. So if the external monitor has that, you could plug the Apple TV into it.
Babyt
May 24, 2010
1,013
64
They use it in a laptop way, but it would be nothing for me to hook the hd up. If anything I would just put the movie(s) on my computer until I'm done with it so they aren't around it.
Thanks for answering my questions :)
lemoon
Oct 28, 2010
216
11
Well, think you have already got the Apple TV 2?
Just do it, you can use handbrake to use the Apple TV as a home media centre! Tough you have NetFlix and Airplay.
For AppleTV info, this wiki collected some useful tips: http://wiki.awkwardtv.org/wiki/AppleTV_2
Jmjacj00
Aug 28, 2011
No. It doesn't do anything...although it is nice if you like extra wires, little plastic boxes, and inevitably a computer laying around the room.
imutter
Apr 4, 2011
5,994
775
Somewhere between DC and Baltimore.
BabyT I was thinking of you yesterday haven't heard anything in a while.
So now to your questions
I am not certain if a Monitor is working with Apple TV but I would believe so. The hook up is HDMI cable
I was in your situation we had accumilated 100s of DVD's. DVD is an outdated format . I actually sold all mine. Many I have bought for hubby while overseas on deployment. Many titels are playing regulary on Cable. I did not like Netflix because there was nothing new either. I considered Blockbuster but it is not able to stream on ATV. Like some here said it'd take forever to rip the DVD'd and take quiet some storage.
So at this point I have sold my DVD's cancled Netflix. I love to go to the Theaters.
I do hve the Apple TV and I watch TV through my ipad airplay. The movies come from a website. But I have used AVPlayer and AirVideo before.
At this point if you have not gotten the ATV I would rather wait. I just read that Apple will come with a new technologie for streaming and may even offer a service. I believe the cable TV days are counted ...
Also how did you come about 400 DVD's if I may ask?
Hondamaker
May 14, 2007
9,946
655
58
Fairborn, Ohio
I love my ATV. I've used it to watch Netflix and to stream movies from an external hard drive on my Mac with AirPlay. No conversion necessary, nor any reason to import to iTunes.
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
I am curious why watching the DVDs in a DVD player on an hd tv is. Out of the question. Maybe I am missing the point but why go and buy an Apple tv just because u have suddenly a bunch of DVDs. Am I missing something?
And just realized this is a resurrected thread and haven't seen Babyt in a while.
