Should I upgrade to 5.1.1 if I'm waiting to jailbreak?
voxnbass
Mar 25, 2012
9
I have a new 4s with 5.1 and no SHSH blobs. I'm anxiously waiting to be able to jailbreak. Will updating now be a bad idea?
Thanks in advance for the feedback! I'm a newer iOS user.
iphonewarrior
13,847
699
If you want to jailbreak, I would stay on iOS 5.1. There is a jailbreak in the works, it hasn't been released yet but when it does you'll definitely be notified on here :)
You can update to 5.1.1 if you want. The jailbreak pod2g is working on is compatible with the Apple's latest firmware version (5.1.1). It might only be a few weeks away.
voxnbass
Mar 25, 2012
9
thanks all.... I woulda posted here but wasn't sure how to find the jailbreak forum from the app. I'm following pod2g on twitter and now checking here for status updates:). Coming from rooted Android devices, I thought I would be able to hold off on jailbreak but..... naaahhh! I wanna :-D
iphonewarrior
13,847
699
Yar... but it's not released. The jailbreaking vs updating argument has always been the same, whichever way you look at it. We/I (not you of course) always stay on the current jailbreakable (preferably un-tethered) firmware until a new perfectly working packaged un-tethered jailbreak is released.
@ OP - Suppose if you weren't already jailbroken my point goes out the window. I was simply referring to orthodox methods.
voxnbass
Mar 25, 2012
9
nope...I'm not jb and never was. I updated the device to 5.1 and then regretted it. I think I'll hold off on the upgrade just in case - I hope release is near....I'm jonesin
Tinman
4,334
183
Aridzona
The OP can still save blobs on 5.1, as Apple is still signing 5.1. Then he can update to 5.1.1 without any fear of losing a chance to jb (although I think there is almost no chance that the upcoming jb won't work with 5.1.1).
Even without blobs saved, as of this writing you can downgrade from 5.1.1 to 5.1.
Michael
Yes, but the OP is on an unjailbreakable firmware version with no way to downgrade. 5.1.1 has been confirmed to be compatible with the jailbreak by the hacker who is working on the upcoming jailbreak, so I wouldn't avoid updating for that reason alone.
iphonewarrior
13,847
699
Yes, but the OP is on an unjailbreakable firmware version with no way to downgrade. 5.1.1 has been confirmed to be compatible with the jailbreak by the hacker who is working on the jailbreak, so I wouldn't avoid for that reason alone.
That wasn't my point, but it's not important. (y)
I'm looking forward to the new jailbreak, since getting the new iPad all I want to do is jailbreak it!
voxnbass
Mar 25, 2012
9
I updated to 5.1.1 as pod2g tweeted a couple of times that the jb will work with it, so I'm all set and just waiting now......I need to read up on how to back up that stuff while I wait.
I'm Kelly, btw....female variety. Nice to meet all of you :)
snowtrooper1966
Dec 10, 2009
2,589
1,316
54
Clarksburg, WV
Welcome Kelly!
You are in the right place to get he most out of your 4S once the jailbreak is released. There are so many things that can be done to increase the customization and productivity of iDevices once they are freed!
I personally focus on customization. It's great to see the amazement of folks with a stock iPhone when I "slide to destroy" (thanks Europa!), and hear an X-wing blasting the Desth Star apart!
There are members here that go above and beyond, really knowledgeable and willing to help.
