Show my Caller ID button gone?
budala15
Nov 17, 2013
150
iPhone 5S
Since I upgraded to ios7 my "show my caller id" button is gone. How can I get it back?
Any help is appreciated!
Sent from my iPhone 5S using
Se7en.8
Oct 7, 2012
19
I am running iOS 7 on the new iPhone 5S and I have that option still there. IDK maybe it has more to do with your carrier.
Sent using iCafe app
budala15
Nov 17, 2013
150
I have Verizon and ios6 had it?
5,578
Is the option missing or is it just greyed out and toggled off?
Check if it appears after you toggle airplane mode on and then off.
budala15
Nov 17, 2013
150
Option is totally gone.
budala15
Nov 17, 2013
150
Airplane mode didn't work.
5,578
Have you tried resetting your network settings?
budala15
Nov 17, 2013
150
Just tried that and is still not there.
5,578
Alright. Hopefully, someone with a Verizon iPhone 5s will chime in and post if the option is still there for them. It's possible that Verizon removed it. I have an AT&T 5s and the option is still there.
After verifying that Verizon still supports this, you could try restoring.
6,682
49
is your profile on the phone a carry-over from your previous phone? and if so, was the previous phone jailbroken? I'm on iOS7.0.4, on an iPhone 5, and I have it in settings under phone. Its between Call Waiting and Blocked.
Had to add that I'malso on AT&T
budala15
Nov 17, 2013
150
No I had it in ios6. I upgraded to ios7 and it's gone.
Ledsteplin
Oct 29, 2013
4,849
1,002
66
Florence, AL
I have Verizon as well, and I don't see that option in my settings. May have to dial *67 then the number to block your ID.
Sent on iPhone 5 using iCafe app
6,682
49
I really wish verizon would get with the program. janky old network holding customers back.
Ledsteplin
Oct 29, 2013
4,849
1,002
66
Florence, AL
I've had Verizon for about 12 years, and I can only think of 1 time I felt the need to block my caller ID. That was an ex wife issue that's all gone under the bridge now. If I had the toggle in settings, I'd probably never use it. Why does everyone want to block their caller ID? Just curious.
6,682
49
If I am returning a call that called a different number and I don't want them to have my cell number. That's just one example.
5,578
It's in easier to just use *67 than go into settings, adjust it, make the the call, then go back into settings to adjust it back?
6,682
49
Since Att went digital, I haven't been able to use the * command codes.
5,578
I have an AT&T phone and just tested it a few minutes ago to see if it still works. It worked - the call showed up as unknown.
budala15
Nov 17, 2013
150
Verizon is horrible!
