Significant Call Drops
netshadow
Apr 21, 2007
40
Upstate NY
I have an iPhone 4Gs on AT&T and have noticed significant call drops over my past iPhone 4. Was wondering if anyone else was experiencing the same? "Significant" is 3-5 times a day!
Iloveiphones
Aug 5, 2010
6,237
234
chatsocially.com
4S. That is not normal at all. The antennas are designed to not drop calls. Try a hard reset, or restore. It may be your coverage though. How many bars do you have?
jaydoc1
Sep 23, 2007
608
With the exception of one dropped call in an area that I ALWAYS dropped calls, I haven't dropped one yet.
iOmen
Oct 16, 2011
22
I smell something fishy here. A large wave of people in 2 days with iPhone complaints. I call a spammer
I've been having a lot of dropped calls with the new 4s compared to the iPhone 4. With the 4 I've never dropped a call or had a call failed in the middle of the call. I'm on AT&T in Texas.
rom x
Jan 18, 2011
1,048
99
are you using both phones raw dawg style or are you using a bumper on the 4 and not on the 4s? just trying to get to the root of the problem is all.
iOmen
Oct 16, 2011
22
bumpers on both. And also haven't noticed yet on ios5.0.1. Haven't made many calls on the new software lol. Will see for sure during the work week.
iphonewarrior
13,847
699
Every new person on eiC isn't necessarily a spammer. Although we have had a voluminous amount of spammers recently. Most of them being copy and pasted posts from MacRumors.
iOmen
Oct 16, 2011
22
Keep in mind this was before the update. So would really need
To see this week what happens plus I'm going to Albuquerque new Mexico for the week. Results could be different up there.
Iloveiphones
Aug 5, 2010
6,237
234
chatsocially.com
I'm just trying to troubleshoot here. Let's see if the antennas are bad. Do you have speedtest on your iPhone? Test that on 3G and see how it does. This may tell if there is something wrong, but most likely not. Worth a shot. Then share it with us. This really shouldn't be happening as the 4S is designed to not drop calls and to switch off and on the antennas while on a call to not drop them.
iOmen
Oct 16, 2011
22
I don't have speed test. Do I use while on a call?
iOmen
Oct 16, 2011
22
Is this what u wanted? I just downloaded and ran test. Let me know if u need further tests.
Iloveiphones
Aug 5, 2010
6,237
234
chatsocially.com
so if my antennaes are bad, would that mean new phone if I take it in to Apple store?
Yes sir. From the test, your speeds are fine. Better then mine. :) I'm guessing it's either AT&T or your phone. Try calling Apple first. It's free! Ell, it hasn't been 3 months yet. 1-800-MY-iphone (1-800-694-7466)
See what they say, have your serial ready.
iOmen
Oct 16, 2011
22
I have Apple care plus also. And they just put an Apple store here in el paso. So do I just tell them I'm getting a lot of dropped calls compared to my iPhone 4. And that I've tested the speeds which are good according to you.
