SIM card and warranty question
iphone62907
Jun 25, 2007
100
i read the FAQ. iPhone comes preinstalled with a sim card. will my current ATT sim card still work? i ask because i will be going somewhere where i do not want to break the iPhone, and want to bring my old phone. do you think my old phone and old sim will still work? or how can i use a differnt cell phone? also, is Applecare or any type of warranty going to be available?
RyanFavre
Mar 16, 2007
250
Milwaukee
nope can't swap in your old sim card. that sucks in so many ways, can't wait to type in all those contacts from my old phone :(
iphone62907
Jun 25, 2007
100
ye that will suck, but i just need to know this: when i don't want to have my iPhone with me, is there a way i can use another phone? meaning, is the sim in iPhone removable? is there any way i can use a differnt phone instead of the iPhone sometimes?
mlass
Jun 19, 2007
678
Q. I'm an existing customer. Can I swap out my current SIM card and start right away?
A.
No. iPhone must be activated befroe it can be used. iPhone includes a pre-installed SIM card for your convenience.
Doesn't sound like there is a different SIM in it.
debest74
May 4, 2007
244
Palo Alto, CA
That has me worry 2. If I go to the beach or something like that I don't want to take my new phone....don't want sand all over it. I guess once u activate your new phone with your new sim card (already inside the iPhone)...the old one it's not going to work (I don't think 2 sim cards with the same number will work)
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
No. Your current At&t SIM card will be deactivated when you activate the number on the pre-installed sIM card in the iPhone.
Now we may get lucky and be able to remove the sim card from the iPhone and use it in other handsets, but some people are saying it's a proprietary size and will not work on other handsets. I don't guess we'll know for sure until Friday.
I hope we can remove it, because I like to use different phones from time to time. I sure don't want to take my iPHone out on the boat when I'm going water skiing with my buds.
lucky8926
Jun 16, 2007
217
Central IL
I'm with ya, I really don't want to input all my contacts in manually. Hopefully they can copy the info with their nifty little sim copier they have!
I also like the convenience of being able to pop your sim out and put it in another phone if you need to. It's saved me a few times when my battery was dead (which is quite often with my blackjack)
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
Exactly right. Once your new SIM card in the iPhone is activated, your old sim card will be invalidated. If you try to power on your old phone with your old sim card still installed it will say something like, "Unregistered SIM" instead of At&t in the carrier alpha tag on the home screen. It'll turn on, you just won't get access to the network.
Hopefully, we'll be able to pop out the new sim from the iPhone with a paper clip to put it in our old handsets when we need to.
Youngbinks
Jun 4, 2007
7,617
33
Atlanta, Georgia
I had to get a phone replaced and I didn't feel like entering in all of the information and contacts myself so they transferred all the numbers from my old sim card to my new 3g one (when I got the blackjack) within a minute or two, so I would assume they can do the same with the iPhone. Otherwise, it'll just give me more practice to type on the new iPhone :).
ebrunn
Feb 6, 2007
711
Minneapolis
Its probably just a new Att 128k SIM card. Most of the current subscribers are still have Cingular devices and SIM cards so now would be a good time to get a Att one. Not that it really matters which one you have.
"Pre-Installed" probably means already in the SIM tray. probably so less technical people dosen't have to worry about putting it in
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
Or just make sure you have all your contacts on the computer you'll be syncing the iPhone with. If you've got a PC and Outlook or Outlook Express it won't be a problem. It'll read your contacts and your calendar and transfer them right to your brand new iPhone. That's what I'm doing. I'm not typing in all those numbers again.
If you've got a mac, then you'll do the same thing but with their programs like iCal and mail.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
That's what I'm hoping too. I sure want to be able to use my old phones still if I need them.
