SIM card swap for work
jjvaldez
Jul 3, 2007
2,615
35
Salinas, Ca
i do some construction work on the weekends and do not want to ruin my iPhone... can i swap out the sim card to an older phone while im lifting sheet rock and 2 by 4s all day so that i can ruin my old crapy phone rather then the iPhone...
thanks
kcarr91
Apr 14, 2007
62
ya you should be able to and you are talking about switching to your old AT&T (cingular) phone
Sleeper
Jul 21, 2007
256
Yup, as long as the phone can accept an AT&T signal then you're good to go.
Velodog2
Jul 19, 2007
562
Wow, that's interesting. Will the sim in my iPhone fit/work in my old razr that I used with att (cingular) before?
UnseenLlama
Jun 20, 2007
171
Indianapolis, IN
Yes. All GSM phones have a "standard" SIM card. You just need to make sure you have activated your iPhone first. Then you can switch whenever.
Being able to switch your SIM card is a big plus for GSM networks. All your account information is stored on the SIM. That's why there is a big market on eBay for selling unlocked GSM phones. You are able to import phones that would normally take months/years to get into the US. AT&T and T-Mobile are the major GSM carriers in the US.
jjvaldez
Jul 3, 2007
2,615
35
Salinas, Ca
thanks for the info... one more thing and i sure that it is not a bid deal but i'd like to get a second.. do i have to turn off the phone first or does it not matter?
thanks
UnseenLlama
Jun 20, 2007
171
Indianapolis, IN
thanks
Yes, you should always power down the phone before taking the SIM card out. To turn off the iPhone, you simply hold the top button for a couple of seconds and then slide the prompt when it comes up.
tarfan
Jun 15, 2007
27
Just Info
New to AT&T moved over from sprint could i buy lets say a razor or black jack and when iam at work use black jack off my sim card from my iPhone
UnseenLlama
Jun 20, 2007
171
Indianapolis, IN
Yes you are able to. Spring/Nextel/Verizon do not use a GSM network. Everytime you switch phones you would have had to call in or go to a store and a rep would setup your new phone. With SIM cards, you just need to take out the card and swap it with a different phone.
Just be sure that the RAZR is compatible with ATT/Cingular's network.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
As long as it's an AT&T or Cingular GSM phone it will work just fine. The only feature you won't have on the other phone is visual voicemail.
AND make sure to dock the phone before trying to open the sim tray on the iPhone. It will only open when the phone is installed in the dock.
UnseenLlama
Jun 20, 2007
171
Indianapolis, IN
? I've opened the sim tray with it undocked.
