SIM card?
JASmine
Jun 22, 2007
Am I correct in believing that I will have to reenter all the contact info on my current sim card into the iPhone..or into a pc/mac contact program and then sync? Kind of a pain for those of us who use the sim card as our principal storage media....and don't have the interconnect cable to a pc/mac.
Please tell there is a simple/cheap way to do this.....
wjp09
Feb 25, 2007
2,559
25
NJ
The iPhone will sync contacts, however if your current numbers are saved to you phone then you must save them to your sim card if infact we can use our existing sim cards.
JASmine
Jun 22, 2007
I think I read yesterday that "while you can use your own sim card it's recommended to use the card that comes with the iPhone"....?
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
Not sure why they're making this recommendation unless the new sim card is a larger sim like maybe 128k instead of 64k.
Lazarus
Jun 6, 2007
380
Miami
i believe that when you buy it they should be able to copy your current SIM card to the new iPhone one.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
That also may be why they want you to use the installed one on Friday instead of your own. They might not have time Friday to be transferring data from your old SIM to your new SIM.
DD0
Jun 21, 2007
183
Can sim cards be transfered into the iPhone? Haven't seen anything about that and it would make things a bit easier. Fortunately I have all my contacts imported to my Mac, but I was wondering how that would work.
iJohn
Jun 21, 2007
384
Long Island, NY
johnburke.tumblr.com
All the information I have seen here and in other websites states that the iPhone sim card cannot be removed. If you read the posts about how the iPhone will be registered, a lot of people "in the know" are thinking that they will simply scan the barcode of the phone to activate it (either through an AT&T system or an online thing).
DD0
Jun 21, 2007
183
Well that's too bad. Not the end of the world though, fortunately the only feature that actually works on my Pearl with my Mac is the address book import.
mlass
Jun 19, 2007
678
The information I have read says that the SIM tray is on the TOP of the Phone and a Paper Clip will be needed to remove it. As for the design of the Sim Card it has not been confirmed. It is said to be a different design and will not fit in other phone.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
I think this is just to discourage people from using the iPHone on other accounts.
I'm pretty sure the SIM card will be a standard SIM card. It might come pre-installed, but a simple press of a straightened paper clip should allow you to swap out your active SIM and put it in your older phone when you're going water skiing with your buds.
lucky8926
Jun 16, 2007
217
Central IL
Hopefully it will be able to be used in other phones. There have been a few times where my battery was dead on my blackjack and I needed to make a phone call. Pop my sim out and put it in someone else's phone and I'm in businesss! If the iPhone sim card is in fact completely different we won't be able to do this..... Grrrrrrrrrr
Bootlessjam
Apr 15, 2007
102
The iPhone DOES have a SIM tray. I would be very surprised if it was a completely different SIM card.
emerrill
Jun 14, 2007
126
Yeah. If it can't move between phones Ill be pissed. I like being able to take my RAZR around when I want something small, or when I'm doing something that I'm worried I might damage the phone.
Lacrosse4life31
Aug 3, 2007
54
Okay, I have had my iPhone for 3 weeks, ever since I received the update, it says I need a SIM card.
Well, actually, where the connection bars are supposed to be it says "no SIM" I can't go on the internet, or do anything that requires a connection. :oops:
Help?
all serious help is greatly appreciated.
Thanks.
Lacrosse4life31
Aug 3, 2007
54
Well, after i downloaded the update it worked fine for about 2 hours. Now it says i need the SIM card, well, I plugged it back in thinking that it would update and all that crap but it hasn't done anything. Currently I'm going to go through the settings again...:mad:
I hope you understand what I'm going through, I'm crapping out bricks in my pants. I need my phone for Monday.
mlass
Jun 19, 2007
678
I had issues with no service, no sim, and invalid sim. I removed and reinstalled sim, no problem since.
You do not have to reboot if you turn on airplane mode and then back off.
Lacrosse4life31
Aug 3, 2007
54
I don't even have a SIM card in there to begin with, it was working well all up until today when i got the new download... sorry forgot to mention.
