SIM not inserted?
HBOC
Aug 4, 2008
108
Portland, Oregon
my phone has been doing this since day one. Has this happened to anyone. Just randomly says "Sim not inserted". Had to turn it off and then on. it happens in the middle of a call as well.
daddyd302
Jul 13, 2008
108
You might want to take it in and have Apple look at it. It could be software related or hardware malfunction. Either way take it in, sounds like it's defected.
Amahk
Jul 21, 2008
30
I get this also. I use to turn it off and that was such a hassle.
Then I thought of just using airplane mode so I wouldn't have to
Wait for the phone to shut off. I know this doesn't fix the problem
but it'll decrease the downtime.
MileHighRob
Jul 16, 2008
1,592
Colorado
Chances are Apple will direct you back to AT&T for a new sim card. They sometimes try to blame things on the sim card anyway so I'd imagine with a sim card error they may send you to AT&T for troubleshooting.
ventrj
Sep 25, 2007
126
I had a problem with this on my V1 they will have you go to the AT&T store to get a new sim if it still does it after you get the new sim they will replace the phone.
MileHighRob
Jul 16, 2008
1,592
Colorado
I agree. They seem to take that approach with a few issues that may or may not be releated to the sim.
Apple124
Mar 11, 2008
149
Do you have a case on your iPhone?
I am down on vacation at my aunts house, and of course I made her buy the iPhone 3G and hers is having the same problem. I then realized it was because the case is so tight on her phone it is pushing the sim try into the phone and it moves the sim out of the detector just slightly enough it doesn't notice it is there. I have been ejecting her sim and then just putting it back in and its fine. Then I put on the case, and I notice it gets tight again. She has the Incase silicone protector
BigCiX
Jul 11, 2008
1,445
Bakersfield, CA
mine did that when i dropped it from a low distance. i just turned it off then on and it went away
HBOC
Aug 4, 2008
108
Portland, Oregon
i don't have a case on my iPhone. It just happens randomly. Also, my home button is getting stuck in the down position. hmmm...
thanks for the replies. i will try to take out the sim card and re-installing it...
BigCiX
Jul 11, 2008
1,445
Bakersfield, CA
Button stuck too. how long have you had your phone? I'd take it back if i were you.
cabinets
Jul 20, 2007
409
Atlanta Ga
Wow! This happened today to me. Twice. I went to Apple and he said try a new sim at first, but I insisted on a swap and they agreed. I'm syncing as I write.
