SIMm Card
Jan 16, 2009
3,230
59
Mississippi
Does it matter if you use an older simm card that the ATT rep took from a motorola instead of the one that shipped with the 3 GS?
I'm still having WiFi issues as it will connect to my network but it runs a page fast, then a couple pages later it's slow then it drops signal and asks for my password again.
Double post, sorry but I asked about the WiFi 20 threads ago.
Thanks Again
Leo
Nov 9, 2008
900
137
43
30
Calgary, AB
It depends. If the SIM card is not the 4000 series, there may be some issues with the iPhone 3G S.
Adam1389
Nov 20, 2008
588
Ilwaco, WA
The WIFI issue isn't the SIM card. You can run the iPhone off WIFI without one. Check your router settings, you might need to get the firmware on the router updated.
