SIMport help
Lancerx
May 7, 2008
Hi guys, i'm a newbie, i have read a lot of information about how to transfer to the iPhone, i have logged in with file zilla so i have created a folder at applications/Simport so i have transfered the files and reboot the iPhone but when i load Simport it starts and search wait for a couple of miutes then the application closes, i have reinstalled couple of times but no changes.
Thanks for any help
Lancerx
May 7, 2008
that's ok, i fallowed this this tut:
Go to your Installer on the bottom right press Sources on top press Edit push Add, a window popup and type without erasing anything rep.frenchiPhone.com check the spelling and push OK press Done and Refresh now go to Install and in Categories find the folder FrenchiPhone.com open it and search for SIMport press it and on top right press Install your springboard would restart and you'll see Simport app
