SIMs 3 crashes
ashwini
Jun 2, 2009
334
India
www.ashwini.co.in
I was playing the sims 3 and after every 10-15 mins of play, the app would shut down! anyone else facing the same problem?
28,365
5,507
It sounds like you might need to free up some system memory. Apple just pulled the plug on the apps that free memory, but if you already have one and haven't updated it, use it to free memory before playing that game. If you are running apps in the background, try disabling them. I also recommend rebooting daily to help decrease the incidences of problems like these.
Jun 30, 2009
231
There may be some problem in the source where you have downloaded. try uninstalling and reinstall. that may work. if does not work try restoring.
