Siri and dictation stopped working
hot_mamma311
Aug 13, 2007
188
Chicago
Has this happened to anyone else after software updates?
I have the 6s and it worked fine last weekend, now nothing. But voice memos and videos work fine for sound.
Rafagon
Dec 7, 2011
7,567
1,254
45
Miami, Florida
I haven't experienced your Siri issue, and this may or may not work, but try going to Settings > General > Siri, and turn her off, then back on. After that, change her gender to male, then change his gender back to female.
Again, this may or may not work; I'm trying to get her to "reset" for you.
hot_mamma311
Aug 13, 2007
188
Chicago
I tried that and no luck :(
I'm hoping after the next update Siri will work again. For now I'll just be frustrated lol
Rafagon
Dec 7, 2011
7,567
1,254
45
Miami, Florida
Well, look on the bright side. At least the Siri lockscreen vulnerability is also gone from your phone…:D Just joking. I will keep my eyes open and if I see anything out there about Siri issues after 9.0.2, I will post it here.
Rafagon
Dec 7, 2011
7,567
1,254
45
Miami, Florida
Here's an older article (pre-iPhone 6s) but the symptoms described match yours (voice memos work, but Siri doesn't). It describes how to test if your secondary mic is working.
http://urbantornado.com/2015/04/21/...-working-for-you-on-your-ios-device-try-this/
If your second mic works, I would suggest powering off, and back on. If that still doesn't work, a "Reset All Settings" might be in order.
5,578
Have you tried a hard reset? Press the home and power button at the same time and let go when you see the Apple logo. It's similar to a reboot. No data will be lost.
hot_mamma311
Aug 13, 2007
188
Chicago
Yep I tried all of these things before I posted.
When I'm in my car Siri will work through the car mic. So weird how it just stopped.
hot_mamma311
Aug 13, 2007
188
Chicago
Thought I'd update-
Finally brought my phone into the apple store and it failed the audio test so they replaced it.
