Siri help
Mi-Phone
Feb 4, 2012
80
Hi all, I can only use Siri on wifi is there a setting or hack to make it work off of wifi? I can tell you I don't get the best service in my area and not sure that could be the reason
Also is there a hack somewhere I can use to switch between carrier towers? I came from a motorola photon 4g and there was a hack to switch to carrier networks so you could get better signal. Basically it would allow to switch from a sprint tower to a Verizon tower to get the best signal all the time, thanks for any suggestions
It should work on 3G. I'm thinking the problem is your poor signal strength. I'm not aware of tweak that will allow you to manually switch towers. There's an app called Signal (Cydia) that maps nearby towers and their strength as well as showing you the one you're currently connected to, but it doesn't allow you disconnect from one and switch to another.
Brett123
Feb 24, 2012
OP, how's your signal strength when you're using Siri? Make sure you have 3G enabled, too.
