Siri not working with custom labels
viren
Jan 21, 2012
Foz do Iguaçu
When I ask Siri to remember x as my wife, she adds the same to my info and it shows up correctly, but when I ask her to call my wife, she says Have put this info manually and tried too! There is no wife number for me.My info under Siri is correct and so is the relationship info. When I turn Siri Off n then on it finds my wife number n dials it correctly, but it only does that ONCE Pretty weird huh! The second time around it again gives me "the same number not found" message. Have configured every thing correctly and am using icloud. If i ask her to call my spouse, only then she finds the correct contact and Dials BUT I WANT TO ADDRESS HER AS MY WIFE.( Have done the labeling correctly too) She even calls my daughter correctly (who is listed as my child in the relationships) Go figure! kindly help if u can figure this out...cheers,
Iloveiphones
Aug 5, 2010
6,237
234
chatsocially.com
I think I can relate, but I'm not clear of the situation you posted.
I'd say call home, it will say there is no home phone number, would you like go use 1-800-275-2273 (that is the home number) and I will say yes. Then it will say calling home.
Is that it?
viren
Jan 21, 2012
Foz do Iguaçu
But in my case she says there is no number for wife and gives me MY own number as an option to be dialled instead of my wife's !
