SiriOus - Siri Dictation
iphonewarrior
13,847
699
You will need to add the repo: apt.if0rce.com/
This Cydia app basically allows the user to dictate in a Siri type fashion. I'm pleasantly impressed, it actually works.
Enjoy.
FYI - This isn't a port of Siri.
Lon
Jun 5, 2010
2,946
132
Alaska
What exactly is the Repo? Your text doesn't match the message in the attached image.
Lon
Jun 5, 2010
2,946
132
Alaska
This DOES NOT work on 3GS or iPad 1. Unless I have to do more than just install it.
iphonewarrior
13,847
699
I made a few spelling errors when I took the screenshot. Dave has reposted the link with the http://
I should have said it was for iOS 5 users.
Lon
Jun 5, 2010
2,946
132
Alaska
Did you read the opening post? Yes... it works :)
Well, it may for you. Which phone? It doesn't work on my 3GS (early bootrom) and it doesn't work on iPad1. Both are on iOS5.0, jailbroken. And some on other forums have not gotten it working on 3GS either. Thus, the question.
iphonewarrior
13,847
699
It works on the iPhone 4. I've not tested it on any other device. Hope that clears things up (y)
Lon
Jun 5, 2010
2,946
132
Alaska
I do believe you, however the forums I've read say that it does work :)
Yes the forums say that members are reporting that it works on the 3GS. However, reading the comments sections show that it does not work on all. It may be just the old bootrom, but there is mixed feedback. I have not heard anyone report that it works on the iPad though, which is odd since it apparently works on the iPod. Oh well. It's new and may be adjusted down the line.
