Slider Messages
the_mia_team
Aug 16, 2007
can someone tell me how to change the slider message, like slide to unlock and slide to power-off, i mean i changed mine with a simpson one right now but that was already pre-made and i just copied it with manzana, i cant figure out how to go into the springboard.app and edit hte text myself
Josh
Jun 9, 2007
Can someone clue me in to where this text file is located in the phone? Thanks!
Casetay
Jul 29, 2007
45
how do I pull that file out of my iPhone? or how do I go about changing it? I am also using a mac
Kipper
I just modified my "slide to unlock" to "ECS RACING". I used WinSCP and used the right side of the screen and went to the directory that SilentKilla posted. Save a copy of the original just in case u mess up and opened the file with WordPad, edit what needed to be edited then save as.
tcram10
Sep 11, 2007
im and idiot
i forgot to backup my springboard.strings and messed it up it would be a big help if someone could post that orginal file thankss in advance
cboyle4
Jul 27, 2007
22
Denver
If your using a mac, download iFuntastic 3.5.5. Follow their instructions to unshackle it n stuff, then there is an option "File Manager" where u can go through your iPhone like finder.
Use the directory:/System/Library/CoreServices/SprigBoard.app/English.lproj/SpringBoard.strings
and you can edit the text right in ifuntastic (without having to put it back onto your iPhone.) Make sure u save file when your done editing the strings.
its so easy, good luck
gyftid
Sep 15, 2007
i have a pc, and i am pretty new to this whole modding thing. how can i change the slider text with my pc? thanks!
i3fan8760
Jul 27, 2007
29
Can someone just make me one that says: "I Solemnly Swear that I am Up to no Good" - for the unlock and "Mischief Managed" - for powering off.
Youngbinks
Jun 4, 2007
7,617
33
Atlanta, Georgia
Ok well I made one with both of those messages, the only problem is that "I Solemnly Swear..." is too long, so you only see the first bit. But here it is anyway, just tell me if you want something else. SpringBoard.zip Also, I haven't uploaded a zip before, so tell me if I did it wrong or you need me to do it some other way.
i3fan8760
Jul 27, 2007
29
yes i think u did something wrong because the link doesn't exist and i don't know how to post it..
TomTomTuning
Aug 10, 2007
196
Camp Hill, PA
I wonder if i could use MobileFinder and MobileTextEdit to do this.
Might give it a shot.
I just don't think i can edit system files like that.
