Slider Question.
Oct 28, 2007
24
Whats the name of the Sliders, Like on the Power Off...Unlock, and Call?
Like if you just want to replace the ones in springboard.app folder.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Are you talking about what it says or the actual slider itself? The actual sliders are called:
The actual messages that the phone says like "Slide to unlock" can be edited in the file:
1. Springboard.strings
Oct 28, 2007
24
The actual Name for the Slider
The actual name for the slider PNG in the springboard folder.
Are you sure those are it? Just put the sliders in my folder and it didn't work...
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
I'm absolutely positive those are the PNG names. I've replaced mine numerous times already.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Also, the PNG's aren't located within the Springboard.app folder. They've in the Frameworks folder. Telephony.UI to be more exact.
Oct 28, 2007
24
You know what
You know what... i think i know why its not called what you said it was called...
i have a iPod Touch, and i thought (since it uses the same Firmware) that it would be the same, unless it is...
Would post this iPod Touch section, but its kinda slow and not updated and stuff...
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
That might have a bit to do with it, but why did you ask about the slider and refer to "call"?
Oct 28, 2007
24
I was talking about it, and it just came out lol...
Would do it in Customize, but doesn't work in Touch.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Haha true. Yeah I don't use customizer but I wasn't aware it wasn't available for the touch. I would imagine that the files would be in similar locations though, so it's weird you cannot locate them.
