small question..
iphoneluverr
Aug 28, 2007
348
im getting the iPhone very soon and i had a question
i have a tonnn of contacts on my moto slvr and i was wondering if i actually have to sit and put them alllll in again...
skiz420
Jul 28, 2007
371
Boston
well first do you have a data cable for your phone? and if you do... i would hunt around google or howard forums to see if there is any software to pull the contacts off the sim to outlook.... thats what i did with my nextel but it was a 930 so i could do an active sync on it anyway...
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
take the phone with the contacts to att and they will load the contacts onto a flash drive that they will SELL to you for a couple of bucks. You take it home and load them to your computer and then synch to the iPhone. Good luck
gijohn
Jul 22, 2007
172
69
Mac or PC?
Can you Export your contacts as a text file in any way from the Slvr?
STNLESS
Jun 20, 2007
76
I had the SLVR and I used bluetooth to sync it with my MacBook Pro address book. When I plugged in my iPhone EVERYTHING synced into the iPhone.
iphoneluverr
Aug 28, 2007
348
so did you finally get your free phone through yourfreeiPhone.com?
believe it or not, you were the last person i needed to do this for me... if you did your offer, i would forever be grateful, it says you signed up but u didn't do a offer
