iPhone 6s Smashed screen
Mrallank59
Jan 8, 2013
253
31
Today I broke the screen on my 6s+. I used to wonder how some one could be so clumsy. My question: do they do decent work at those mall kiosks, where they replace phone screens?
At was an avoidable crash. I had taken off the LifeProof case to use my Olloclip. The good part is, atleast it fell flat on the screen. It did no damage to the sides. Thanks for any info
Some regards
Allan
Some regards
Allan
Going through Apple is optimal since they have certified technicians and their work won't void the warranty, but if you are looking for a cheaper option, they typically do good repairs elsewhere. Check with them to find out if they guarantee their work and inquire about the experience of the technicians.
I noticed that you started another thread about your iPhone not booting. Did this drop cause the phone to stop booting? If so, you may have internal damage and I recommend going through Apple in that case. If these two problems are related, let me know and I'll merge your threads.
  • Like
Reactions: tranbachtuongx5
Mrallank59
Jan 8, 2013
253
31
Thanks, Europa. I figured it would cost around 300 dollars. Is Apples price comparable to that? I'll call my local Apple Store, tomorrow to find out. Thanks for the advice.
Apple charges $149 to replace the screen. However, the cost will be higher if there is internal damage that also needs to be repaired. Were you able to get it to boot up?
Mrallank59
Jan 8, 2013
253
31
I just got my screen replaced. Apple wanted 299. A guy at the mall did it for 220. Every thing works fine. He even put a screen protector on it.
  • Like
Reactions: Napoleon PhoneApart
Trystan
Apr 14, 2015
I would use iMax repairs, very good service and reliable, and also very helpful, they're not the cheapest but they use quality parts, and they also use registered and insured postal service
  • Like
inapplewetrust
Jan 24, 2017
That's a nice saving, I wonder if there is a difference in the screens these guys typically use vs Apple's. Are you from the US OP? 299 for a screen sounds very expensive.
