SMS correction feature
bonerfortuna
Apr 9, 2007
25
I must be missing something. When Im texting with my fat fingers and the intuitive box suggests what I actually want, how do I approve and use what it suggests instead of what I type? Thanks
aggieman
Jul 6, 2007
4,053
85
Dallas, TX
just keep on typing like you normally would or hit the space key. if you don't want hit touch the word on your screen to 'X' it out.
lilnef
Jul 2, 2007
125
is there a way u can type leys say u type a word and it gives u a suggestion but its the wrong one. i really don't know how to explain it. like on my sprint i would type and click down through the auto correct words i can pick. can u do this
brinky
Jul 24, 2007
95
50
Atlanta, Ga
If I am understanding you right, the answer is no. The iPhone give you only one suggestion that you can either take, ignore or backspace and start over. Of course I have found that I have to backspace all the way to the end of the previous word including the space between the works to get the auto-correct to start working again.
wildonrio
Jul 4, 2007
2,002
Provo, UT
I've noticed the same thing. Also, when you are typing something in Safari, have you noticed that sometimes the autocorrect won't work at all and you have to close Safari and go back in to get it to start working again? I've noticed this happening since the new update and it is pretty annoying.
lilnef
Jul 2, 2007
125
yes you understood me correct. its sad but at least now i know im not missing something. i thought i was there but i wasn't able to manage how to do that, but thanks for clearing this up
