SMS notified
terrapin
Aug 3, 2009
349
Chicago
Is there any way to disable the popup box that appears when a new SMS comes through? I know how to disable the preview but can I disable the box from even appearing?
terrapin
Aug 3, 2009
349
Chicago
Yes it is my friend. I tried bite SMS but from the springboard it would flash open for a millisecond then close
RossMc
Jun 28, 2009
1,124
Newcastle, UK
Get Intelliscreen from Cydia
You get a 10 day trial then you have to buy it, You can disable the pop up screen in that app
