SMS sound alert even when set to "none"?
Kristen Mogo
Jul 19, 2011
Boston, Massachusetts
So my iPhone has been jailbroken for a while but have recently installed some new apps mods etc (i have glaskart wb theme, mobilenotifier, other jb apps)
The most recent thing I installed before this issue was "iBlacklist"
All of a sudden when i would get an sms I would get double the notification; so it sounded as if i was getting two texts
When i go to the iPhones settings and set the sms alert to "none" I am still getting an alert; but now it is just one.
Any thoughts ideas on how I can fix this without re jailbreaking my whole phone? It's pretty annoying.
crystus
Jul 5, 2009
258
Deltona, FL
What other apps. do you have bite or ireal sms? Been a while since i used mobile notifier but did you check there to turn off any alerts?
altjx
Oct 21, 2009
411
www.altonjsupport.net
That normally happens if you have more than one messaging app. What I'd try doing is hiding the original SMS app using SBsettings. I believe this will stop the sound coming through for that app.
Did deleting MySMS fix your problem?
