SMSD vs WeTools - which do you recommend?
enigmanic
Jun 27, 2007
513
I've been using WeToolsUS for awhile now. I like it, although there hasn't been any recent updates to it for awhile. I've noticed a few threads mentioning SMSD. If anyone has used both, can you tell me which one you prefer?
Alexander
Jun 28, 2007
1,724
Atlanta
Started off with WeToolUS because I digged the slick interface, but later rediscovered that SMSD had some serious functionality updates. I switched over to it immediately. While I don't use it regularly, it definitely excels past WeToolUS in terms of features offered. Hope this helps. :laugh2:
wildonrio
Jul 4, 2007
2,002
Provo, UT
SMSD is better. It's more simplistic yet has more features, such as being able to create a new text. WeTOOL doesn't do this, and has a bunch of funky English misspellings.
enigmanic
Jun 27, 2007
513
Thanks guys! Looks like I'll be switching over to SMSD...
connie
Jul 11, 2007
2,839
104
So Cal
SMSD works great! One of my iPhone wish list items come true.
Now if I could just get the MMS to work on my iPhone:(.
termleech
Sep 7, 2007
1,154
McPherson, KS
What do you use WeTool for? SMSD will only send SMS messages (to multiple people and such, it works great). However if you are looking to delete individual phone calls you'll need to use WeTool as well. Personally I use SMSD for all my text messaging that requires me to send it to multiple people and it works great. I've tried both, but just didn't like WeTool very much.
jaydoc1
Sep 23, 2007
608
There's a program called CallD which will let you delete the phone calls much like SMSd.
H
Hayesimus
Guest
well I opted for wetool just so I wouldn't have to have two sep icons. But my question is this. Does smsd work alone now. Luke someone said it can create texts too. So could I download it and hide my regular SMS app and be on my merry way? Would this cause any problems?
jaydoc1
Sep 23, 2007
608
Yes you can create new texts right out of SMSd. Answers to those texts are going to come through your regular text program, though.
H
Hayesimus
Guest
well the texts would show up in smsd also would they not?
jaydoc1
Sep 23, 2007
608
Yes. The SMSd just doesn't show them threaded.
Sep 29, 2007
348
SMSD is better functionally. It works with the tweak to letting your inbox have over 1000 messages and also it shows the idicator showing you have a message. Also it sends multiple messages faster compared to weTool. weTool looks much better with its transactions and its pages but doesn't function aswell. If you notice with weTool it also adds a 1 before the number so if you have a 1 in front of a number already it goes 11********** and wont work.
My 2 cents.
jscaffidi
Nov 14, 2007
20
smsd is functional but def NOT a replacement for the native sms ... try them out side by side and you'll see.
H
Hayesimus
Guest
well if it can't replace it then i'm just gonna stick with weTool. I don't do a lot of mass texting anyway. i just liked it for its delete purposes and i'd rather not have to have two sep deleting apps. Text and Calls. now if SMSD was to adopt a call deletion ability then i'd check it out. I just want to keep my springboard uncluttered for the most part.
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
When i downloaded SMDS from the installer it said I needed to download a program called ULCTL. What exactly is ULCTL?
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
Thanks. I was wondering why it didn't ask me to install it when I installed SMSD this morning.
