smtp outgoing mail fails to connect 4 out of 5 AT&Tempts...
goblues38
Sep 7, 2007
49
I know the setting are correct. I can pull down mail everytime. BUt my out going mail only connect to the server 1 out of every 5 or so attempts.
This is on edge or 802.11. Any ideas.
pkells1
Aug 9, 2007
20
i've got the same problem but i don't think mine ever connects....i haven't been able to send mail for about a week.
Peter2oo2
Jul 5, 2007
try going into to the email option's advanced settings and turn off SSL. See if that works.
goblues38
Sep 7, 2007
49
didn't help, anyone else?
I fixed mine.
1. Sync your iPhone.
2. Uncheck the tab to sync email.
3. Undock phone
4. delete pop mail account
5. power cycle phone
6. click email button, you will be prompted to set up a mail account
7. manually set up your pop mail (make sure you have your settings from your provider)
8. It should now work.
The auti sync had some incorrect settings for me anyway. This fixed it. I am golden now.
