So disappointed by iPhone 5
Trondemann
Oct 20, 2011
45
I have an iPhone 5 and an iPad 2, and my iPad is much faster downloading movieclips from for example youtube, and others sites that contains clips. This is on my WIFI at my home. On sites that i am only reading text, my iPad is much faster......i am not Happy with this.:-((
Sent from my iPad using Tapatalk
Trondemann
Oct 20, 2011
45
They both almost have the same speed on the speedtest. The problem is When i for example want to watch a clip on Facebook , the iPhone uses much! Longer time to start showing the clip. Why is this ? U know?
Trondemann
Oct 20, 2011
45
We don't have an Apple store here :-(
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
If I were you, I conduct some tests. First off, was Speedtest, which they both seem to share the same result. Try some random YouTube tests. See if it just happens to be Facebook. Also, are you in the same part of your home when conducting these tests? Both devices benefiting from the same signal strength?
Finally, you could try rebooting your router and your iPhone. Sort of a fresh start for both parties. Sometimes that's all that's needed for any device that's not having a good day with Wi-Fi.
Trondemann
Oct 20, 2011
45
Will do . Appreciate answers :)
I just tried with my daughters iPhone 3GS the speedtest, and her Ping was over 300, compared to mine 157. But my speed was maybe 35% faster .
Jun 19, 2007
33,487
4,549
Upper Marlboro, MD
Try resetting network settings on your iPhone. Settings>General>Reset>Reset Network Settings. You'll have to put in your wifi password again afterwards.
Chancellor
May 28, 2011
278
25
I'm not really sure if this helps, but I would try using the browser on iPad and iPhone and clicking on the videos through Facebook and monitoring the results.
You never know when the apps actually cause lag- I don't really think this is it, but you never know.
jmp316
Jul 10, 2008
1,048
141
Agreed with everything that's been said above. Do some resets: reset the router, reset network settings, hard reset. If all else fails you could also try to restore the phone as new, it could be the result of a corrupt backup... Good luck!
6,682
49
I can confirm that a bad backup can fubar your phone. When I got my iPhone 5, I couldn't send regular text messages- only iMessage to other idevices. There was a corrupt setting I. My iPhone 4 backup. I had to dump and start from scratch.
Here is something else to consider. You need to put both devices side by side on a table and test at the same time. There is going to be slight variances, so you need to run a series of tests with speediest.net. They should average about the same. If they do not, then you need to go to another wifi source and do it again. If there is still a difference, call Apple support and tell them your problem.
Now, if the majority of your problems seem to stem from Facebook -accessing videos and websites, then it could be the app. Delete it, sync your phone and reboot. Then add it again and see if that makes a difference.
FB on my phone crashes at least once a day and its either lightning fast or slow as hell.
That brings another point. Make sure that your as close to comparing Apples to Apples when doing tests. If the Facebook on the iPad hasn't been updated at least once since last summer, then you have different versions and that could be the problem too.
Sent using iCafe app
28,429
5,552
I've always followed this rule: Never restore a new phone that's running a new firmware version (5.0, 6.0, etc.) from a backup that was created on an previous generation of firmware and hardware. I'll restore from my backups throughout the year, but I like to start fresh with each new model of the iPhone. There is less potential for problems that way.
jmp316
Jul 10, 2008
1,048
141
I've never done that, but plan to do it with my next phone... Just don't want to lose all that data, texts, etc.
28,429
5,552
You don't lose anything except texts and game saves. You can restore the texts if you jailbreak and you can save them to your computer if you don't.
28,429
5,552
Try this on the iPhone:
1. Delete Facebook and then reinstall it
2. Settings > Safari > Clear Cookies and Data
3. Reboot
And this on the iPad:
1. Settings > Safari > Clear Cookies and Data
2. Reboot
Now, while both devices are connected to WiFi, select a page in Safari with a video and load it on both devices. Then press the play button on the video on both devices at the same time. Record and upload the results if you'd like.
6,682
49
After watching that video, I go back to my earlier post that you need to try at another wifi location. If its happening there as well, then I would call Apple support.
Apr 8, 2013
21
The internet speed of my iPhone 4S is slower than my iPad, though I am using same WiFi for both devices.
