so how do i add /opt/iPhone/bin/ to my $PATH
qryptiq
Jul 21, 2007
75
i get this message after certain installations. just wondering if anyone knows how to do this?
thanks
ciaran00
Jul 21, 2007
242
In /var/root/.profile
Add this line:
PATH=$PATH:/opt/iPhone/bin/
You can do it through ssh, winscp, etc.
ciaran00
Jul 21, 2007
242
Ok, so all .something files in unixish OSes are hidden. Go into terminal and type:
ls -a
If a file named .profile doesn't show up, then create one using one of many methods:
In terminal or via PuTTY: "pico .profile" (without the quotes).
Add the line:
(hit return once more)
Then do a ctrl-x. If you are in terminal then use the bullet dot on your KB as ctrl. Save it.
You can also create a file using WinSCP.
please report back if it works for you.
BTW, ".profile" is just a text file.
Another warning! I have seen next line (CRLFs) being borked if I do editing of .profile in Wordpad. Use the editor that comes with WinSCP if you have to...
