so if i go to at and t and buy a new iPhone what version firmware is on it?
southmade
Jun 29, 2007
44
does the store carry iPhones with 1.1.1 on it already ?
or will it be 1.0.2 ?
can i just use the old iunloick method without updating to the new software ?
or is it safe to say that its impossible to unlock any iPhones as of right now?
gcvt
Jun 21, 2007
1,029
San Francisco
Nowadays it seems more than likely that it will have 1.1.1 installed on it.
Not sure about unlocking as I don't keep up on that stuff.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
I wouldn't say it's impossible but it certainly a lot harder than it has been in previous weeks. DO NOT try and unlock a 1.1.1 phone unless you want a BRICK. If you have 1.1.1 then you need to downgrade to 1.0.2 for sure.
Joker
Aug 1, 2007
or is it safe to say that its impossible to unlock any iPhones as of right now?[/QUO
I have bought 3 in the last week and all have the 1.0.2 loaded.I read on here somewhere that you can check the serial # on the back of the box and the 4th and 5th # is the week it was made,and I think week 39 and on has the new firmware.
entong
Sep 21, 2007
154
i would say that u will get firmware 1.1.1 installed on it. but don't really to worry about that. u have 3 choices in here:
1. wait till fw 1.1.1 fully cracked by dev team, meanwhile u can use iPhone features except phone :p
2. downgrade it to 1.0.2 firmware and unlock it then u will be able all the features of your iPhone.
3. keep on 1.1.1 firmware .no unlocking.. just using at& t services. then u should be able to use all the feature on your iPhone. but no other provider simcard can be used on your iPhone if you're not unlocking it :)
