So is anybody's 4s battery better than before?
GreenMother
Jul 1, 2009
171
I'm curious how your iPhone 4 battery life is since iOS 5. Mine seems the same if not worse.
RoofMonkey
Jun 21, 2010
8,913
1,979
Is the phone in a case or 'naked'? Of its in a case it could be the opening is causing it. ?
Sent from my iPhone4s using iCafe app
Target
Oct 16, 2008
1,139
161
The Great State of WV.
My battery life is worse on my iPhone 4 after iOS5 by 25%. I take it off charge at 6:15a and by 11:00 I'd be in the 30's. Now after the upgrade, I have to charge it to make it through the evening.
It is the same in my lifeproof case and naked. But I don't think I understand why that would make a difference.
Target
Tattooed Alex
Oct 24, 2010
3,050
809
Denver, CO
My iPhone 4 seems to have an improved battery life with the iOS 5 update, although I felt that it was good prior to the update also.
jareknyc
Aug 27, 2007
715
NYC
my battery is great, i don't have issues with it on my new iPhone 4s, maybe even little better...
stil29
Jul 28, 2008
44
My battery seems better. Calibrate it first then turn push to manual. Then use notifications only on apps you use. Also close all apps at night.
rollinfromhell
Aug 1, 2007
1,232
44
How do I turn the push stuff to manual? I am getting notifications left and right when all the badges and stuff are still turned off and my apps aren't opened.
NewGuy
Dec 30, 2009
432
Toledo, OH
www.facebook.com
It has been taken apart so you can compare the values:
iPhone 4 = 3.7 V 5.25 Whr = 1420 mAh
iP4S = 3.7 V 5.3 Whr = 1432 mAh
As you can see, the 4S has a bigger battery. Not by much but still bigger (in capacity not necessarily physical size).
cliffeman
Oct 13, 2007
2,142
66
Feenix, Amizona
I have noticed my battery life is worse than my old iPhone 4. But I'm gonna let it drain and then give it a full charge. See what happens after that.
Prozium12
Jan 22, 2012
352
35
Uk,Manchester
I was always worried about battery life on my 4s turning locations off and notifications but recently I've been using these as what's the point in having them if there turned off and I have to say I'm well happy with battery life getting two days at least,take that one x..
mobileAge
Aug 27, 2012
Two suggestions re. battery life is screen brightness and GPS usage. Rather then have the iPhone set the brightness for me (Auto-Brightness ON is the default) I turn this OFF (Settings app -> Brightness) and then use the slider to turn the brightness down to a lower then normal level, but still easily readable. I find this definitely helps my battery last longer. Also if in the car and using GPS, be sure to have the unit plugged in as active GPS tracking seems to be a bit hit on battery life. Hope that helps.
Franniej74
Aug 28, 2012
thanks for the tips for sure! my 18 yr old has the the iPhone 4S and her only complaint is the battery life. She charges it every night but it still dies duroing the day. I will pass this on!
Maggot
Aug 29, 2012
Also if you press the circle button and twice you can see the program's running in background, hold them and a minus sign will be seen, press and it delete and also saves on battery.
Dawg1234
Aug 31, 2012
4s battery is pretty bad unplugged it at noon now it's 7:30 and says less than 10% remaing. Although I just the phones not lasting a whole day is the new standard that we all need to get used to it a buy extra chargers, car chargers, and battery packs. Wish we could just buy extra batteries tho.
sonic1519
Jan 26, 2011
25
I have found on my4s if you leave the bluetooth on all the time when not needed it will
drain the battery also
Kgd0630
Aug 8, 2010
330
33
Anderson, SC
Two days at least, ? Are you saying that your phone lasts that long without charge? There's no way.
