So it seems as if I'm locked outta my phone
Monspeed
Oct 18, 2010
heres the situation
Yesterday my phone crash and got stuck at the Apple logo so i restored it , i had it jailbroken and unlock and run on tmobile so after the restore everything went fine but then iTunes said my sim card is not a valid sim card and it locked me outta my phone so my question is can i just continue and rejailbreak it on 4.2.1 and it will unlock or am i screwed
fijiman
Feb 13, 2011
832
64
UK
You have updated your baseband...no way back... no unlock...You can roll back firmware if your shsh blobs are saved
If you restored to a standard 4.2.1 ipsw, you now have a baseband that is non-unlockable, but there is still at least one method for unlocking it.
1. Is it a 3G, 3GS or iPhone 4?
2. Did you restore to a custom 4.2.1 firmware with a preserved baseband or did you use a firmware that was downloaded in iTunes?
3. If it's a 3GS or iPhone 4 and you restored to 4.3.5 (didn't do a shift+restore), do you have a 4.3.3 or lower SHSH backed up in Cydia?
Monspeed
Oct 18, 2010
its a iPhone 3g standard 4.2.1 firmware various sources say it is still unlock using redsnow and installing ipad bb but the new problem is redsnow keeps getting stuck at uploading ramdisk and wont finish the jailbreak
Monspeed
Oct 18, 2010
thank you so much it worked and now my phones back up and running but now every 15mins springboard crashes is there anything i can do to stop this
