So what's up with the 4s cases
Robbinhoodz25
Jan 31, 2011
110
I've heard that the iPhone4 case won't fit the 4s and may or may not be compatible with the Verizon one either. So does anyone really know?
jarofclay73
Jun 23, 2008
2,387
Honolulu, Hawaii
It seems that the button layout is very similar to the Verizon iPhone and not at all like the AT&T iPhone. So, that means you can't use AT&T-only cases. You'll have to use cases meant for the Verizon iPhone. Some places are actually selling 4S cases, like Otterbox, but not everyone has 4S-specific cases.
BrownGem
Feb 27, 2009
1,623
22
Texas
Guess if you are using a case that has a cutout for every single button you may encounter a problem. My case will fit the new phone perfectly.
Test-Pilot
Jan 20, 2008
118
9
hmm... so for all the people that were disappointed that Apple stuck with the exact same form-factor: maybe they'd be happy(er) now?
  • Like
Reactions: Robbinhoodz25
theorioles33
Jul 21, 2007
925
135
USA
From what I understand, the button on the upper left (silent switch) is lower on the new model like on the Verizon version. If your case/bumper has an elongated opening, it will fit both. If its more precise like mentioned above, it will not fit right.
Here is a good pic to compare. Looks like the volume buttons may be a hair lower as well. Maybe not enought to make a difference.
The iPhone 4s on the left, 4 center, Verizon iPhone on the right.
