so yeah kinda need help
lowram00
Feb 11, 2008
468
memphis TN
ok i want change the background in the sms but say you have use ssh where i get the solfware and all
lowram00
Feb 11, 2008
468
memphis TN
ok im trying change the background in the sms but i see the Library for but i don't see theme
psylichon
Oct 31, 2007
16,591
751
41
Philly
Try root/var/stash/theme****
It mirrors that other theme directory. I do all my theming from there.
psylichon
Oct 31, 2007
16,591
751
41
Philly
Ok, that's "var/root".... that's what you see when you first load WinSCP. But click that drop-down menu that says "root" above the right pane, and go to the top level "root"
Then you should see the "var" directory and you can go from there.
lowram00
Feb 11, 2008
468
memphis TN
ok i do that and i still don't get anything to theme like i need
