Software Download Problem
MikeMz
Sep 2, 2011
Anytime I try to install a new program I get an error saying that some components are missing and download failed.
Any ideas what the problem might be? Thanks in advance.
Mike
5,580
Sorry for the late reply. We'll need some more information to help you. Is you Mac up to date? What applications are you trying to install?
MikeMz
Sep 2, 2011
As far as I know I am up to date with, regardless I just did an update to ensure this. I am trying to install Lion OS.
Thanks for the help.
Mike
5,580
Okay, post back if it doesn't work after the Lion update.
MikeMz
Sep 2, 2011
That is what I am trying to install and I am getting the error message.
iphonewarrior
13,847
702
You're getting an error message when installing Lion?
What is the error message?
MikeMz
Sep 2, 2011
The error message stats that there components missing download has failed....I did have this once as well installing PhotoShop.
Thanks,
Mike
iphonewarrior
13,847
702
Have you updated your OS to the latest version? Click on the Apple (top left) and select Software Update. You may need to update to the latest version before performing other software updates. Also, are you running Snow Leopard or Leopard?
MikeMz
Sep 2, 2011
I am not sure what OS however it is what ever came with my mini which I purchased a year ago. I will do the update and try to reinstall.
iphonewarrior
13,847
702
How did you get on after the software update? If you purchased your Mac a year ago it will more than likely have Snow Leopard on. I'm assuming you're trying to download and install Mac OS X Lion via the Mac App Store?
MikeMz
Sep 2, 2011
Yes. It appears I am getting all the files but they won't install for some strange reason.
iphonewarrior
13,847
702
Have you tried restarting your machine?
MikeMz
Sep 2, 2011
Yes I have. I think my only option may be to bring it by the Apple store.
iphonewarrior
13,847
702
If/when you take it to the Apple Store, post back here and let us know what the problem was. This could potentially help other users in the future.
15,385
1,089
It may be there was an error with the download, which is more likely with large files like Lion. Might be worth deleting and trying to redownload Lion before making a trip to the Apple store.
