Solving iPhone problems
Freddie
Sep 24, 2007
Wondering the best way to solve iPhone problems.
Great phone but recently it seemed that the phone will not ring when called.
I had this problem a month ago and it was solved by my plugging in the earphone and then removing it. I thought that it might have something to do with listening to music on the iPod function. Today I cannot (again) get a ring tone (only vibrate) when someone calls. (I recently used the iPod function which I don't do that often)
Any advice?
Thanks,
Freddie
Freddie
Sep 24, 2007
OK I got a solution
Any advice?
Thanks,
Freddie
I took the advice that someone posted for newbies to do a SEARCH.
I found out about the D... switch on the side that I did not know about (the silent switch) and somehow tweeked when I put the rubber thingy on my iPhone.... (no jokes here....)
And putting the switch in the right position solved my problem.....
Kabeyun
Jan 10, 2007
665
Northeast US
Well dome, Freddie! Glad you found a solution here.
I guess the answer to "Wondering the best way to solve iPhone problems" is join EverythingiPhone.com! :cool:
-K
