some lagging issues
mayniak
Aug 30, 2009
76
miami
so im expereiencing some lagging with my phone. i don't know why seeing how its a brand new phone. is anybody experiencing the same issue or can someone help me on how to fix it?
iNinja
Aug 8, 2008
3,984
20
UK
Where are you seeing the lag? In a particular app or in general? Also, is it after a period of use or after you wake the phone? Really need more details....
28,365
5,507
A stock 3GS shouldn't have any lag. Has it been a while since you rebooted it? I recommend rebooting once every day, it helps tremendously in preventing problems like these.
Sep 19, 2009
9
Really?
Booting once a day seems excessive. I just bought a 3GS, I hope i don't have to reboot it everyday to see good performance.
iNinja
Aug 8, 2008
3,984
20
UK
When we say "reboot" - that literally just means switching on and off really. I never switch my phone off and on, i just hold the home and power buttons for about 30 seconds and the iPhone reboots. I think that is what Europa suggests, and I would say 2-3 times a week is adequate.
mayniak
Aug 30, 2009
76
miami
Well when I try to go on aim or any app with Internet it tends to just sit there, I would hav to close the app and reopen it in order for it to actually load. Sometimes I get force closes to. And I have 13.86GB so I don't see why a memory problem would be the issue
iNinja
Aug 8, 2008
3,984
20
UK
The amount of GB you have available wouldn't cause lag... lag would occur when you have low amount of RAM or a slow processor.
28,365
5,507
mayniak, turn it off and turn it back on and then let us know if you notice a difference in performance. What you are referring to is storage space (Flash memory...aka hard drive space on a computer). Lag is often caused by low system memory (RAM). There used to be apps that allowed freeing memory, but Apple hobbled them. So now, we have to do it the the old fashioned way, rebooting.
mayniak
Aug 30, 2009
76
miami
eupora i did what you said and im noticing a difference. hopefully it doesn't happen again. thanks for the help
28,365
5,507
Cool. Your phone isn't jailbroken, right?
You can't respring if it isn't, so you have to reboot. Just try to reboot it at least every few days and it should run better for you.
28,365
5,507
I want V back as well, not only does he symbolizes human freedom and individuality, he now will symbolize freedom of 3GS, returning when the official JB is released!
mayniak
Aug 30, 2009
76
miami
no my iPhone isn't jailbroken, don't plan on doing it either. when theres something i really want then i might do it but until then im ok
