Something up with wifes phone help pls
trueblue
Dec 6, 2008
17
My wifes iPhone seems to have frosen,, and I cant get it back workin for her,, ,, ,I have tried to hold down the power button on the top right, to reset the phone but it has NO effect,, the phone seems stuck on a favourites page,,,when you press the main button at the bottom,,,nothing happens there either ? We have tried pluggin in the charger ,, but it seems to make no difference,,,,,any ideas pls help ,,
Adam1389
Nov 20, 2008
588
Ilwaco, WA
Try plugging in to iTunes and see if it will sync. If not you are going to have to do a restore. Try holding power and home for 10 seconds until it shuts off, then turn it back on and see first
trueblue
Dec 6, 2008
17
cheers reset seems to have did the trick,,,never had to hold the home and the reset button before ,,,but cheerss anyway
