Song Will Not Play
Jul 25, 2009
Hi all,
I have the IPod Classic 80GB with about 2,926 songs on it. A few weeks ago I loaded this one song on it, it plays from my ipod on iTunes, but when I try to play it in my car or on my home stereo it will not play. It jumps back to the previous song every time. I select it as I would do any other song. Has anyone experienced this and know what the problem might be? I even put it in a play list all by it self, it would not play. Plays in iTunes though.
Thank You
5,578
What format is it?
It sounds like it's not in an iPod compatible format. iTunes will play more file types than the iPod will.
Another possibility is that you have the sync only checked songs and videos box checked, but the song itself isn't checked.
Jul 25, 2009
Thanks for your response, how do I tell what format the song is in?
Jul 25, 2009
It had to be converted to mp3, Thanks for your help
