Sony car stereo not reading iPhone eat
Tonynlia
Oct 15, 2011
32
Hope somebody can help.
I used to be able to plug my iPhone 4 into my car stereo using its USB connection, but now the car stereo just has READ flashing on it. It does not start to play my music, I use USB Rather than Aux because It also charges my iPhone (I also use my phone as a satnav) another thing that happens it when I unplug the e phone from the car stereo is that it stops any external sound until I go to sound settings and tap on any sound , the external sounds then work. I could use Bluetooth to play my iPhone songs but I cannot scroll through my albums on the stereo that way. Any help appreciated.
Tonynlia
Oct 15, 2011
32
Ps
My iPhone is jailbroken , but it still used to work after jailbreak
5,580
1. Turn off the iPhone
2. With the Sony head unit turned on, connect the iPhone to the stereo via USB
3. Allow the iPhone to boot up and the phone and the head unit should successfuly interface
Bennyboy
Jul 21, 2010
14,017
1,756
PA
I had that happening on my bimmer a lot, usually a hard reset would fix that. It could also be a problem with the stereo, try plugging in somebody else's iPod/iPhone to see if you encounter the same problem. Is it a factory brand stereo?
Edit: nevermind the last part, forgot its a Sony.
Tonynlia
Oct 15, 2011
32
Thanks every one ,I will try that in the morning and see how it goes
