Sorry for noob question. Can someone help me guide me how to Unlock & Jalibreak a 2G
Grifftech
Dec 14, 2007
46
Sorry for the dumb question but I have never attempted this before and I have a 2G phone with version 3.0 on it.
My wife and I both upgraded to 3GS and would like to sell this one. I have heard that if it is Jalibroke and Unlocked it sells for more.
Is there a difference between Jailbreaking and Unlocking?
What steps do I need to take to Jalibreak and Unlock?
Thank you for your help,
Chris
iphonewarrior
13,847
701
Grifftech
Dec 14, 2007
46
iphonewarrior
13,847
701
don't thank me, thank the original poster who made the guide.
Glad you've got your self sorted :sneaky:
Grifftech
Dec 14, 2007
46
Quick question, how do I unzip the Red Sn0W, its a Torrent file and I have never messed with those before :)
NM, I did a little research and realized I needed a torrent app like BitTorrent and that is just a link, so I am downloading RedSn0w now I think ;)
Grifftech
Dec 14, 2007
46
Once i have followed that guide and Unlocked and Jailbroke how can I tell if it is Unlocked?
28,365
5,507
If you have friend with T-Mobile, you can put their SIM in it to verify that it worked. If not, you could probably just take it in to a T-Mobile store and see if they can check it for you.
Are you only unlocking it to sell it? I would definitely unlock it if you're selling it, the value of the V1's has plummeted since the 3GS has been released. I think they're going for less than $175, and that's unlocked.
Jailbreak it with redsn0w and then reboot and the T-Mobile SIM should work.
http://blog.iphone-dev.org/
