Sound editing software
Daywalker7
May 12, 2007
141
I have a program called Polderbit Sound editor.
With this I can cut down an mp3 to any size I want. So now instead of having a whole song taking up space as a ringtone, I can chop it down to 20 seconds at any part of the song I want.
The software is pretty cool because it allows you to also record any sound coming from your pc.
Say you want some obscure sound from a random website, and there is no way to download it, just turn on Polderbit and record it.
pb30
81
Minnesota
You can also do this in iTunes (its fairly rough though). Right click a file -> Properties -> Options -> Set start/stop time to the section you want -> Right click and convert to AAC.
You then have your ringtone. Be sure you unset the start/stop time on the original file.
