Sound on iPad stuck in headphone mode
Pandatheamanda
Dec 31, 2012
Ah! I need help. The volume for my iPad is stuck in headphone mode. I tried shutting it off and turning it back on, putting the headphones in and back out a bunch of times, and I went to sound settings.. Nothing's working.
ivantwilliams
Jul 14, 2009
1,546
218
If you try holding the home and power button at the same time and restart it. Does that help?
Sent using iCafe app
liberated
Jul 19, 2007
3,238
484
If it doesn't work, then it's probably hardware rated, call Apple.
RoofMonkey
Jun 21, 2010
8,924
1,984
With music playing, plug & unplug headphones into the device a number of times very quickly.
RoofMonkey
Jun 21, 2010
8,924
1,984
Hi, if it is the system issue that causes the issue, you can try to update your iPad software to fix the problem if there is an update available. In order to avoid losing data during the process, you may also use a repair tool like Joyoshare UltFix to help you. These two methods are proven to be effective by those who have experienced the same problem as you. I hope to be useful to you as well.
Check the date of the original post.... almost SEVEN years ago!
