Sound setting issue?
May 30, 2008
21
Last night when I plugged my iPhone in to charge, it "vibrated" and today the keyboard ticks and the ringer are not working. I did not make any changes in the settings, the vibrate setting is currently in the off position, the keyboard tick button is in the ON position, and the ringer is turned up. So...did I bump it or something for this to happen? Any ideas?
Leah
nishant_81
Mar 3, 2008
33
If you haven't already re-stored, then simply try re-starting the phone. I face this issue sometimes, and re-starting it generally corrects it.
Don't Restore or Reboot yet. Sound-related issues are quite commonly fixed by going to Settings > General > Reset and tapping "Reset All Settings."
my95z34
May 11, 2008
45
I have this issue fairly often. Turns out the phone keeps thinking there are headphones plugged in and trys to route the sound there.
When its doing it, try the volume controls on the side of the phone, and see if it says (headphones)
If it does, then there's your problem. Now I have no clue how to fix it. :(
aenti
Jul 8, 2008
1,155
Maryland
All you do is reset your phone, plug in your headphones, and remove them slowly. I've read this on some site. Turns out when this happens, it's because you took your headphones out too quick.
my95z34
May 11, 2008
45
Thing is, I don't use headphones at all. I haven't even put any music on my phone yet.
