Sounds don't work on 3GS
May 11, 2011
I have a 3GS. It's pretty new, maybe 6 weeks old, tops.
None of the sounds are working on my phone.
The speakers are fine, I can get them to ring using the settings.
I tried powering off.
I went to general settings and hit reset a couple times.
I plugged the headphones in and out a couple times even though I have never used the headphones.
I think that's all the normal things to try.
Any help would be appreciated.
Thank you
May 11, 2011
That was it.
Someone figured it out for me.
This isn't a great excuse, but I'm going to use it.
I have the Otter box shockproof cover on my phone, so the switch was hidden.
It was under a flap, but I didn't look there.
Thanks for the help anyway.
May 27, 2012
Lindenhurst, New York
THANKS THIS HELPED ME ALSO. WHAT CHRISTIAN DESCRIBED WAS EXACTLY THE PROBLEM I HAD AND HOW I TRIED TO FIX IT. MY SWITCH WAS ALSO SHOWING RED. WHAT IS THAT SWITCH?
