Space bar, Return Key, and The 123 Key problem!
May 4, 2009
Any one Have solution for this problem
Please help me
The Apple
3,105
Indiana
It sounds like a strip along the bottom of your screen may not respond to touch. If an iTunes software reset does not resolve the problem then take it to Apple.
iNinja
Aug 8, 2008
3,984
20
UK
123 is at the top though alongside the other numbers, can you be a little more specific about "the problem"?
yugenro
May 19, 2009
well, i don't know about Gopal Sharma, but I'm having much the same (i presume) problem: that, when I have a VERTICAL keyboard on my iPhone, the BOTTOM ROW of keys-- whatever they happen to be-- don't work. In most cases, that means the 123/spacebar/return keys.
any ideas?
The Apple
3,105
Indiana
any ideas?
styfle
Mar 31, 2008
3,381
Try another app that uses the fullscreen to see if that part of the screen is working.
yugenro
May 19, 2009
See, THAT'S the problem: in OTHER apps, that part of the screen works just fine! (Well, the ONLY other non-keyboard issue i've found in that part of the screen is the "Bloom" app-- it has its only menu button down in bottom-right corner, and it doesn't work, either... but ALL other apps i've used, that part of the screen works FINE!)
ihack
Nov 7, 2008
202
Orange Park, FL
Are you jailbroken? I had this issue when I had clippy installed. It worked everywhere except on the springboard for me. As soon as I uninstalled clippy it was fixed. So maybe it's an app causing it.?
The Apple
3,105
Indiana
Thats why the software reset is required to make sure it is not a hardware issue. If the software reset does not work, and you are out of warranty or just don't want to visit an Apple store, the new version will be coming out soon so just wait for it.:p
