Speak Auto-Text
Alkali
Nov 1, 2010
243
Nigeria
Dear friends,
I have enabled the above feature but the speech- speed is too fast, how do I reduce it? Thanks very much.
Sent using iCafe app
Dec 15, 2008
5,386
340
27
Pensacola, FL
Once you turn on Speak Auto Text, right above that option is an option for Speak Selection. Once you turn this on, you can slow down or speed up the Speaking Rate (how fast it is read to you.)
Alkali
Nov 1, 2010
243
Nigeria
Thanks very much Money but whether increased or reduced it does work when I star typing. It's super fast.
Dec 15, 2008
5,386
340
27
Pensacola, FL
That is very strange. Have you tried to reboot your iPhone and then test it?
Alkali
Nov 1, 2010
243
Nigeria
I think there is a bug or something because I reboot but same problem.
Dec 15, 2008
5,386
340
27
Pensacola, FL
Have you tried a hard reset where you hold both the lock and home button until it shuts off the iPhone and turns back on?
Alkali
Nov 1, 2010
243
Nigeria
Have done that several times after selecting the speech rate- No difference.
Dec 15, 2008
5,386
340
27
Pensacola, FL
What operating software are you currently running on your iPhone 5? This could possibly be the problem. If not, I hope someone has a solution for you to fix your issue with the fast speech rate.
Alkali
Nov 1, 2010
243
Nigeria
I have upgraded to iOS 7 and the problem started after that Money.
