Speaker and mic not working.
tyoung
Nov 1, 2007
185
So Cal
Well after only having it a little over a month, my iPhone is gonna have to go to the genius bar. It will ring, but won't play songs from the iPod. When I get a call, they can't hear me and I can't hear them. I tried rebooting, and even did a restore, nothing. Hope they can just give me a new phone outright. :(
aggieman
Jul 6, 2007
4,053
85
Dallas, TX
Try taking the earbuds and plugging them in and taking them out a few times. This has happened to me a couple times and I read somewhere that this works and sure enough it did.
tyoung
Nov 1, 2007
185
So Cal
Thanks, I will give that a shot right now.
Edit: Awesome, it worked! Thanks for the help.
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
aggieman is correct, I had that same thing happen and the tip he suggested worked to fix mine. Let us know if that works.
aggieman
Jul 6, 2007
4,053
85
Dallas, TX
no problem! I remember the relief I felt when I found this solution. I was so frustrated when that happened, with the thought of having to return my iPhone.
tyoung
Nov 1, 2007
185
So Cal
That's exactly what I felt too. Definitely a relief with such a simple fix!
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
Not sure but someone once suggested that the contact in the bottom of the headphone plug "well" does not fully disconnect when the headphones are unplugged so you sometimes get no sound and sometimes get partial sound.
