Speed - the free speedometer
sportsfan12321
Jul 20, 2008
43
Cool app, tested it in the car today, seems to be very accurate. One thing though...how does it work? I've turned 3G off and edge as well using an APN mod, but somehow it still is able to detect my speed? I'd assume it uses the built in accelerometer, but it doesn't make sense considering car's velocity is constant at times...
g33k1
Sep 6, 2007
61
San Antonio Tx
GPS I would assume
jpm
Aug 5, 2007
212
It uses the iPhone GPS.
sportsfan12321
Jul 20, 2008
43
I assumed the GPS used a data network to transfer info?
Otherwise wouldn't there be additional charges for using the GPS?
JoeT
Dec 18, 2007
911
Tampa, FL
No! The GPS unit derives its latitude and longitude by triangulating based on signals received from multiple GPS satellites. The software then compares the latitude and longitudes and the time difference between them and calculates your speed. It has nothing to do with your data at all.
There is no charge to receive the GPS signals. You are already paying though your taxes. :)
http://en.wikipedia.org/wiki/Gps
jarofclay73
Jun 23, 2008
2,387
Honolulu, Hawaii
I just dumped Speedbox in favor of Speed. Speedbox would never save my "mph" setting. I had to always change it every time I went into the app.
styfle
Mar 31, 2008
3,381
so if you have the original iPhone, it wont work?
MaxCrack
Sep 16, 2008
Simple Physics
According to the description it uses the GPS so no first gen phones.
There are a few that use the accelerometer. Based on a simple physics formula. The computer can figure it out thousands of times per second.
The best one of this type is Dynolicious. $13 is a lot for an iPhone app, though. But compared to a $200 stand alone unit it is a pretty good deal.
There is one that does perfectly fine for basic speed functions for around $5
==========Formula==========
Vf = Vi + At
Final Velocity = Initial Velocity + (Acceleration * Time)
If your Initial velocity is 30MPH and your acceleration is 0 over a given time then your final velocity is 30MPH.
How, exactly, the accelerometer knows what your rate of acceleration is, I do not know.
