splash top remote to a Linux computer
nixie21
Apr 9, 2012
has anyone been able to use splash top with the Linux computer? I want to be able to watch videos from my computer on my iPad but cannot find one that will work with linux any suggestions. thanks in advance
owieh
Jul 15, 2010
481
60
Sheffield, UK
twitter.com
I think it's best that you look into media server applications for Linux... VNC is not the best way to go about with what you are trying to achieve, watching a video will will have a considerable lag as the refresh rate of VNC won't be quick enough.
I've never tried Plex, but it looks promising. You will have to install the Plex server in you Linux machine the the Plex client on your iOS device.
http://plexapp.com/linux/linux-pms-download.php
owieh
Jul 15, 2010
481
60
Sheffield, UK
twitter.com
I just want to add, that if you just want to be able to remotely connect to your Linux machine any VNC server will suffice, as I've said, watching videos wouldn't be ideal.
So, you install a VNC server to Linux machine then you install a VNC client on your device and set it up.
iphonewarrior
13,847
699
Splashtop doesn't work for Linux as far as I'm aware, unless it's been ported recently.
Check their site, it's only available for Mac and Win.
http://www.splashtop.com/streamer/download?from=remotedownload
You would be better going down the Server route, it's so much easier. You do have to mess around with router settings but it's easy to do over FTP. If you get stuck, simply reply here and one of us will walk you through it.
nixie21
Apr 9, 2012
thanks for the response.. can you point? me to a website that explains the server setup you mentioned? thanks again
Sent from my LG-VM670 using Tapatalk 2
peter38
Oct 16, 2008
Cant you just install VNC to your iPad?
