Spoiled by iCloud: Any Cydia Equivalent?
Michael Baturin
Jul 11, 2007
1,751
244
33
South Jersey
I haven't had jailbroken devices for a while. With this new one, I decided to go for it on both my iPhone and iPad. What I soon realized is that I have to download an app separately on both devices. I'm used to just downloading it one place and seeing it on my other devices. Is there any Cydia equivalent to iCloud - at least for automatic app downloading?
MoneyMaker79
Dec 15, 2008
5,386
340
29
Pensacola, FL
I'm starting to think. Scary huh? What if you buy PKGBackup from Cydia, save everything from Cydia to DropBox on PKGBackup, and then install it again on your iPad? Of course you'll only pay once, I think? Different device saves what you puchased on your Cydia account? Well, if this works then you can just restore a saved backup from PKGBackup. I've never done this before, I only Jailbreak my iPhone 4.
Anyways, maybe there are other easier ways. But besides all of that, PKGBackup is well worth the small money it costs. I think it was like $5? I do not recall.
fijiman
Feb 13, 2011
832
64
UK
Using PKGBackup is a good idea....but you may come across problems trying to load Cydia apps/tweaks meant for the iPhone onto the iPad....Not everything works on both platforms...:)
Michael Baturin
Jul 11, 2007
1,751
244
33
South Jersey
Agreed - the ideal solution would work as iCloud does. It knows if it is made for iPad and/or iPhone and installs on both or not depending. I do not think Cydia is there yet.
MoneyMaker79
Dec 15, 2008
5,386
340
29
Pensacola, FL
Well PKGBackup just let's you restore all that you backed up. My suggestion is to just go manually one by one to make sure each one for your iPad is compatible.
