Sporadic calls not ringing
PDACPA
Jan 16, 2008
542
My wife has tried to call me like 3 times tonight. The first two calls, my phone never rang. She called on another line and I looked at my phone and and sure enough, two missed calls (she even called from her At&T line and a land line).
So we try it again, and it rings fine. I then dialed it from work and rings.
I have done a reboot on the phone twice and did a normal shut off.
Does anyone know if this is an iPhone issue or related to AT&T?
psylichon
Oct 31, 2007
16,591
751
41
Philly
You did the reboot after all this? How often do you reboot? Chances are your phone was just low on memory, which could cause it not to play audio properly. If it still does this regularly after a reboot, something is not right.
Rebooting the phone once a day usually keeps things like this from happening.
PDACPA
Jan 16, 2008
542
It had happened earlier in the day and I rebooted. I am monitoring it today. Tested it a few times after my post ( and a reboot) and it rang each time. You might be right on the memory.
