Spotlight Search
Alkali
Nov 1, 2010
243
Nigeria
Dear Friends,
My Spotlight search works ON and OFF. any remedy please? I have to switch OFF the phone and ON again to work. Thanks.
Mght not be an actual 'Fix' as I have never heard of this happening before, but go into Settings.app, go to General and then to Spotlight Search (SETTINGS >> GENERAL >> SPOTLIGHT SEARCH) and have a look at the order and what is selected to be searchable. Make sure everything you want on is on and make sure they are ordered how you want?
Also, are you jailbroken? I assume you haven't got any tweaks installed which hook into spotlight search screen?
cooter32
Nov 26, 2010
Its very buggy and intermittent. Been searching for a solution for days to no avail. Have done full restore and reset. Nothing fixes it.
Bojan
Oct 17, 2015
What phones do you guys have? When I was on iOS8 with iPhone 6+ 128gb of RAM, I wasn't able to do any spotlight, because of poor RAM.
Sent from my iPhone using the Force alone.
Bojan
Oct 17, 2015
Luckily for me it was solved on iOS9 and later on the new phone
16/64/128 GB is the storage capacity. The RAM is 1 GB on the 6/6+ and 2 GB on the 6s/6s+.
